If i buy CUE Pro, can i use all the plug-ins and extras that are made for VDJ?? And will i be a pro user on this site?
Thanks
Thanks
geposted Thu 06 Mar 08 @ 5:07 pm
Thanks
Thanks
YES
geposted Thu 06 Mar 08 @ 5:10 pm
Beautiful...thanks!!
geposted Thu 06 Mar 08 @ 5:11 pm
Being a Hercules mk2 user will get you a discount if you buy VDJ.
geposted Thu 06 Mar 08 @ 6:33 pm
Don't have the MK2 anymore. I exchanged it the day after i bought it for the Total Control. I emailed support to undo my registration but they said they don't do that, so thats why i still have the icon there.
geposted Thu 06 Mar 08 @ 9:19 pm
while id love you to be a cue member , why not just use the Hercules serial from your download center..
geposted Fri 07 Mar 08 @ 2:12 pm
"Don't have the MK2 anymore. I exchanged it the day after i bought it for the Total Control. I emailed support to undo my registration but they said they don't do that, so thats why i still have the icon there."
I don't have it anymore...and I don't want to use that serial since i don't own the product anymore. I want to be fair to the next person who buys the MK2 i exchanged.
geposted Fri 07 Mar 08 @ 2:15 pm
It's too late for that. When you sign on with the MK2 and used the serial number it's registered to you. Now that you took the unit back the serial number cannot be registered to anyone else.
geposted Fri 07 Mar 08 @ 2:37 pm
And you can still use that serial for the discount, nobody else can, so why not?
geposted Fri 07 Mar 08 @ 2:40 pm
well i can't say i didn't try...but it's not showing up
It only shows the download discount. And i don't know the serial number of the MK2.
geposted Fri 07 Mar 08 @ 2:44 pm
use the serial number of the VDJ that came with your MK2
I did this an got the discount (This was over a year ago)
geposted Fri 07 Mar 08 @ 3:24 pm
If you check yourself into eservice your serial should pop up.
Also if you log into the download center with your forum login password it should be there also.
geposted Fri 07 Mar 08 @ 4:44 pm
See This guy is smart didnt' think of that!
geposted Fri 07 Mar 08 @ 5:04 pm
I tried checking myself into eservice..but Lindsey Lohan and Britney Spears were in line in front of me. I figured my need was not as great as theirs...
geposted Fri 07 Mar 08 @ 5:14 pm
Damn! I was going to say something similar
geposted Fri 07 Mar 08 @ 5:25 pm
Crazy, psycho &^%$#@!*&^*((*&^ think alike.
geposted Fri 07 Mar 08 @ 5:33 pm
Not to exclude the master of ceremonies...lol
geposted Fri 07 Mar 08 @ 10:12 pm
Not me, I don't even know these guys. Plus, I signed myself in, so I can't be that bad.
geposted Sat 08 Mar 08 @ 12:43 am
