when I set the pitch I dont want it to move when I put the next music on
geposted Mon 13 Dec 04 @ 6:18 am
In settings, disable auto bmp in the fame tab. You should be fine.
geposted Mon 13 Dec 04 @ 6:50 am
I disabled auto bpm and still have the same problem. My vdj is a 1.09 I dont know if thats the problem.
geposted Tue 14 Dec 04 @ 5:10 am
Yes. You need to buy the full program and update to the newest version.
geposted Tue 14 Dec 04 @ 5:24 am
Thanks for the help.
geposted Tue 14 Dec 04 @ 5:43 am
