I recently changed the monitor that the S-Video output on my laptop outputs VDJ to. I see both monitors (1) and (2) being properly identified under WINDOWS set up. In addition, I activated TV output in VDJ.
But why is it that all I see on the monitor output is the windows desktop (less icons)???
geposted Mon 10 Mar 08 @ 5:38 pm
1. plug s cable into laptop then boot system
2. go into control panel and make a dual monitor - confirm ( ok )
3. in VDJ> config >video > change settings to your video card
4. depending on version of VDJ ( activate video or enable )
5. start the party
5. start the party
geposted Mon 10 Mar 08 @ 5:59 pm
I did exactly that. But when I activate TV OUTPUT in VDJ, I get a pop-up VDJ Video window on my VDJ screen, and a blank desktop remaining on the S-video monitor.
geposted Mon 10 Mar 08 @ 6:09 pm
In your windows display properties, make sure to tick the checkbox in front of: "Extend my Windows desktop onto this monitor." That should fix it. Also, make sure that the video card is selected in video options in VDJ, instead of (window).
geposted Mon 10 Mar 08 @ 6:47 pm
Under VDJ / VIDEO / TV OUTPUT, there is no other choice listed... Only TV Output. I have an ATI Mobility X800 that should be there...??
geposted Mon 10 Mar 08 @ 6:50 pm
I think I figured it out. The display mode (in CATALYST) seems to be in some kind of clone mode or something. So not only do we have to extend the desktop, but the display mode has to have TV / extended selected under ADVANCED.
geposted Mon 10 Mar 08 @ 7:15 pm
Hmmm... this is a bit confusing. In fact, I want to toggle the S-Video output between
1 - The clone mode for VDJ demonstration purposes, and
2 - The normal VDJ operating mode of extended desktop
In ATI Catalyst software, I can't seem to do this in a predictable way... it seems to be random what the mode is in. Any ideas?
geposted Mon 10 Mar 08 @ 11:04 pm
I wish I could offer more help, Eric, but I don't use that type of card and configuration software. Perhaps someone else has similar hardware, and will chime in.
geposted Tue 11 Mar 08 @ 1:25 pm
