Can anyone help me. When I launch my virtual dj a message appears saying' internal database corrupted'. Can I repair this?
geposted Fri 14 Mar 08 @ 7:37 am
If you are using version 5 - look into the Config -> Browser tab (Explanations in the Manual). If you are using version 4 still then there is a tool in the Downloads -> Plug-ins -> External Tools section that can help - http://www.virtualdj.com/addons/download.html?addon_id=2560
geposted Fri 14 Mar 08 @ 8:34 am
For future reference, after analysing any new tracks, you can make a copy of your database file and save it 'elsewhere' on your computer - somewhere you remember - (like my documents).
Depending on what version you're using, copy the database.xml file and paste it into the 'other' folder. Then, if you get this error again, you can just retrieve it, copy it and then paste it back into where it should be. Then, when you boot up, you should be back to normal.
Just get to know the version quite well, and you'll know where the file should be. In vista, it's saved in my documents\virtualdj, and in xp, it's in program files\virtualdj. You'll get the idea.
Good luck.
P
Good luck.
P
geposted Mon 17 Mar 08 @ 6:53 pm
