Hey guys need some advice on GOOD bass boosters,
I'm running 2 15's 2-ways with a max wattage of about 1,200 a piece with a 5000watt Amplifier all new equipent
So I've got plenty of pushing power but......
Unfourtunitly the bass is horrendous? Nice highs Nice mids' Bass?............. nothing I want the woofer too bounce past the protective mesh lol Well not that much but they barley budge. I was told it could have something too do with the software.....But what's the real culprit? I don't want too distort the sound quailty just want more dedication in the BASS area? What's my best bet?
Thanks
Thanks
geposted Sat 15 Mar 08 @ 2:57 pm
I think you'll need to offer some more info on the set-up to get proper assistance. Sound card info, and sound system info.
I really doubt it's the software tho.
probably some simple setting either in your sound config, or your system.
Don't panic.
Don't panic.
geposted Sat 15 Mar 08 @ 3:37 pm
I TOTALLY agree with DJ Rick - "doubt it's the software" actually, I would go as far as guarantee it is NOT the software.
I run VDJ through the AUDIO 8 DJ sound card then through a high-end high-powered club system in a club that fits >2500 people with no sound problems whatsoever.
Start by hooking up a simple CD player to your mixer (play a good quality clean CD) and see how it sounds through your system. Than should give you good clues as to what is happening.
geposted Sat 15 Mar 08 @ 8:50 pm
no his problem is he has a full range speaker and he is trying to get some low end bass with no sub-woofer bottom it doesn't work that way
your speaker are ment to work one way and one way only. double 15 two way speaker is not design to give you low end droops (low freq) only if the box is design for that you need to invest in some bass bottom boxes that can handle at least 120 hz and below beside the double 15 two ways.(you dont expect to go as fast as harleydavison motorcycle on a mopet)
geposted Sun 16 Mar 08 @ 12:51 pm
