J'étais dans l'attente de pouvoir mettre des plugins sur mon mac pour VDJ Pro mais impossible d'installer les effets sonores téléchargés sur le site??
Des réponses?
Merci
Letudiant
Des réponses?
Merci
Letudiant
geposted Sat 15 Mar 08 @ 5:07 pm
Bonjour;)
Pls use the french forum instead,
https://virtualdj.com/forums/29/French_Forum.html
Thanks.
Thanks.
geposted Sat 15 Mar 08 @ 5:09 pm
Sorry,
Allright, I would like to know how can i install sounds effects on mac (.bundle)?
Cheers,
Cheers,
geposted Sat 15 Mar 08 @ 5:11 pm
Put the bundle in ur sound effect folder which is located at ur plugins folder of VDJ in ur document;)
geposted Sat 15 Mar 08 @ 5:20 pm
Thank you spinna!
http://myspace.com/letudiant check it!
geposted Sat 15 Mar 08 @ 5:23 pm
Your welcome:)
geposted Sat 15 Mar 08 @ 5:32 pm
Thanks for the providing good information - this is really helpful for Downloading Antivirus Software .I found another good one that helped me find a great website for
http://downloadantivirussoftware.org/index1.html" Downloading Antivirus Software
geposted Thu 27 Nov 08 @ 7:15 am
alyysaeden wrote :
Thanks for the providing good information - this is really helpful for Downloading Antivirus Software .I found another good one that helped me find a great website for <a href="http://downloadantivirussoftware.org/index1.html">Downloading Antivirus Software</a>
Huh??
Pls do not hijack the thread. Thank you;)
geposted Thu 27 Nov 08 @ 10:22 am
