hi guys
can anyone explain to me how to install a new font package on my home pc please, do i need to install it in a particular programme i want to use, or will it when installed into the pc be picked up by every programme i use, thanks for any help in advance
Tayla
Tayla
geposted Mon 17 Mar 08 @ 7:31 am
TrueType and OpenType (Vista), you can drop into the Fonts folder, insde your Windows folder.
If you are using proffesional PostScript fonts, you need a font manager, such as Extensis SuitCase or similar.
Also, if you are planning to add LOTS of fonts, use a font manager, cause having LOADS of fonts in your Windows font folder will slow down your system
geposted Mon 17 Mar 08 @ 7:40 am
cheers norway
the package i got i probably be only using a max of about ten of them and just delete the remainder, when installed will these automatically show up in my video editing software or will i have to put the font bundle into each programme
cheers
cheers
geposted Mon 17 Mar 08 @ 7:46 am
hey Tayla ..... just wanted to reiterate , Norway is right about the fonts slowing you up .....def delete the ones you don't use
Chuck , peasant from across the puddle ........
geposted Mon 17 Mar 08 @ 11:24 am
tayla wrote :
cheers norway
As system fonts, they will show in any program ;) Drop them into Font folder inside your Windows install folder.
10 fonts are fine, even houndred. If you ever plan to install thousand(s), use a font manager, and activate needed fonts at any time ;)
geposted Mon 17 Mar 08 @ 11:42 am
thanks for the help guys
these fonts are going no where near gig lappy, as i said there for video editing purposes because what i have now is just the bog standard stuff and these will add something extra to the text
chuck, got a chuckle out of me there, hehe
geposted Mon 17 Mar 08 @ 12:21 pm
can you guys help me ? how do ya get all this white out off the screen ??
geposted Mon 17 Mar 08 @ 2:57 pm
Razor blade Chuck...on the screen...not your wrists....also...it helps if you bitch slap it.....
geposted Mon 17 Mar 08 @ 3:01 pm
"take a letter to the home office " "tell 'em i said , owwwww "
geposted Mon 17 Mar 08 @ 3:11 pm
Got it Chief......owwwww
geposted Mon 17 Mar 08 @ 3:12 pm
chuck, you get that pm
geposted Mon 17 Mar 08 @ 3:15 pm
thanks peasant out
geposted Mon 17 Mar 08 @ 3:24 pm
hehe, need you to get that to me soon as please, want to go watch the match on the main tv
cheers
cheers
geposted Mon 17 Mar 08 @ 3:27 pm
