Peavey SP 4 3-Way Dual Speaker Cabinet or JBL JRX125 Dual 15" 2-Way Speaker Cabinet Pair
What amp would you use?
Am going to buy either one of these. I have a QSC 1450 i dont think its going to be enough???
geposted Mon 17 Mar 08 @ 10:32 am
Are you brit or american?
geposted Mon 17 Mar 08 @ 12:10 pm
You could have provided us with links, so we don't have to look them up.
geposted Mon 17 Mar 08 @ 12:26 pm
geposted Mon 17 Mar 08 @ 12:34 pm
I would say your amp is a little on the anemic side. It is only capable of giving you 450w, clean with no distortion, at 4 ohm, so anything over that, will start to distort. Your amp is incapable of delivering the maximum continuous load. I don't trust the specs on the Peavy. However, even on the JBL, it can handle 500w continuous, at 4 ohm. If it were me, and I had to use this amp, I would get smaller speakers.
For these speakers, I would want an amp that was at least capable of 750w to 1000w at 4 ohms. This way you could pump 500 continuous, and handle any peaks, without any distortion, which kills speakers. There are always peaks.
geposted Mon 17 Mar 08 @ 1:18 pm
what amp would you suggest?
could I use this amp for a few gigs until i gather enough money for a biggger amp or am i risking damaging the speakers or the amp
geposted Mon 17 Mar 08 @ 1:25 pm
Any suggestions would really be appreciated.
geposted Mon 17 Mar 08 @ 3:06 pm
Yes, you can use this amp, You just have to be aware that you do not have any head room with the amp. You can safely push 450w at 4ohm, with no or very little distortion. Anything over that, and you start the distortion demon. This is a great company and they typically rate their amps a little low. The amp will go higher, it just won't be clean. You just can't push the speakers to their full potential. I did not mean to scare you, just provide you with some knowledge. I learned this the hard way. It's distortion that fries speakers.
Any of the QSC PLX or RMX series amps that have a 750w or greater at 4ohm rating.
geposted Mon 17 Mar 08 @ 3:22 pm
I have said before that the amp is piss week.
geposted Mon 17 Mar 08 @ 7:48 pm
If staying with QSC, get a Powerlite 4.0. That should do it.
geposted Mon 17 Mar 08 @ 9:47 pm
JBL is loud, but sounds terrible. Haven't heard Peavey yet, but really: don't go for JBL :/
geposted Tue 18 Mar 08 @ 5:28 am
