Witch is the best controller up there for VDJ software?
geposted Mon 17 Mar 08 @ 1:07 pm
Here we go, so hold on. I don't know which is the best. At the moment, the DMC 2 works great for me, and works right out of the box. There is a mapper available from jpboggis, that takes it to another level, and he continues to update it with each new version. Plus, it is rack mountable, which is the first requirement for me.
geposted Mon 17 Mar 08 @ 1:31 pm
In your case, being a turntable dj Funky-T, I'd say timecode as you currently use gotta be best.
If you want more and easier control, there are midi controllers with scratch decks, such as the new Vestax VCI-300 ( a bit larger platters than its brother VCI-100)
Both, the best controllers out there, in my opinion ;)
If you are a table top/club dj that is...
For rackmounts, there are other choices, as mentioned
geposted Mon 17 Mar 08 @ 1:37 pm
Subject: "Yet another what-is-the-best-controller thread"
Reason: I haven't searched for this subject before I posted this question.
Not to be rude, but there's a similar thread here:
http://www.virtualdj.com/forums/87157/Hardware_Technical_Support/can_any_one_tell_me__what_s_best_to_use_in_controllers.html
You can also check this out:
http://www.virtualdj.com/products/hardware.html
geposted Mon 17 Mar 08 @ 1:46 pm
Pretty smart for a Swede ;) juuuuust kidding.. hehe
(norway makes jokes of swedes and visa versa - and this was one.. hehe.)
geposted Mon 17 Mar 08 @ 2:43 pm
