Hi! anyone who knows where I can go to change my "font" as my playlist is way to small to work with ... I have the newer version of VDJ. I've looked almost everywhere but can't find it... Please HELP! DJ Ronny_bee
geposted Tue 14 Dec 04 @ 4:41 pm
The font size is dictated in the XML file of the skin that you are using. It can be edited. Open the xml in notepad and try to find the correct font that you want to modify and change the size.
(Be sure you keep a copy of the original xml in case you really mess it up)
geposted Tue 14 Dec 04 @ 4:44 pm
ok thanks , so it's not in my "skin then"...I've looked all afternoon at the wrong place. Thanks DJ Ronny_bee
geposted Tue 14 Dec 04 @ 4:57 pm
