Hi. I've found what I think is a bug. When I modify any VST audio effect parameter and then exit the program, the modification correctly appears inside corresponding .ini file. When I execute VDJ again, the sliders of that VST effect seem to be in the position of the .ini file, but when the VST is activated it sounds with its default parameters. If I click over the slider, only then synchronize the parameter with the slider.
Is there any workaround for this?
thanks
thanks
geposted Mon 17 Mar 08 @ 3:16 pm
