geposted Tue 18 Mar 08 @ 6:55 am
anybody??????
considering buying this sub.
geposted Tue 18 Mar 08 @ 2:44 pm
Wattage of sub is kind of low for 18". I wouldn't buy anything if I can't get feedback on it and especially if no ones heard of it.
geposted Tue 18 Mar 08 @ 6:37 pm
Yep am starting to get a bad feeling on these how about some YAMAHA subs
geposted Tue 18 Mar 08 @ 7:46 pm
good ratings but i think that youd be better with a more reputable brand and if you can but it, a powered sub as well - sounds better, no having to worry about the combo, etc
i never like yamaha imo, but ive heard good things
geposted Tue 18 Mar 08 @ 9:03 pm
If i buy powere subs do i have to still buy a crossover??
geposted Tue 18 Mar 08 @ 10:22 pm
No, you don't have to, there is a crossover built in. It will send the higher frequencies, to the satellites.
geposted Tue 18 Mar 08 @ 11:04 pm
I know this topic has been hammered but what would you buy passive or active and what would you buy.
What is better not cheaper
all i have are yamaha sp115s with a qsc 1450 amp
geposted Tue 18 Mar 08 @ 11:30 pm
external crossover will definitly sound alot better than the internal crossover.
May I suggest the "DBX Driverack PA"
http://www.guitarcenter.com/dbx-DriveRack-PA-Processor-101779478-i1125313.gc
geposted Wed 19 Mar 08 @ 12:14 am
I think that the self powered subs from Mackie sound great. There are a little pricey though.
geposted Wed 19 Mar 08 @ 8:54 am
