BBE Max-X3 2-Way Stereo/3-Way Mono Crossover
Any tips on how to set the cross over
I have sp115 yamaha 2-ways on a qsc 1450
I just purchased the Harbinger 18 inch subs with the crown XLSd 802 I was not going to buy these but they sounded great i tried peavey and b-52 and these sounded better. the salesman said b-52 makes the harbinger brand
but need help fine tuning
geposted Fri 21 Mar 08 @ 1:02 am
it should be set on 80%!
no just kidding. dude it just depends on the room & what your doin with it. most likely for your top end your probably going to start cutting of @ 120-150. Subs around 160.
hope u understand that...if u don't u deff need help ;-)
sorry when i have beers in me im only so much help.
geposted Fri 21 Mar 08 @ 1:22 am
Does anybody have this crossover that give me some more advice
geposted Tue 22 Apr 08 @ 12:47 pm
I try not to wear high-heeled pumps if I plan on dancing alot...?
? Oh you said crossOVER tips... never mind, forgot I said that.
geposted Tue 22 Apr 08 @ 1:01 pm
Still messing with the crossover anybody familiar with this piece of equipment.
Am still work in process.
geposted Wed 30 Apr 08 @ 9:28 am
