i went to set up for my gig and adjust sound
virtualdj software would not play on the second deck
the fader was right i checked volume i have the mk2
it work fine on thursday night
what do i do need some help fast gig starts at six
geposted Sat 22 Mar 08 @ 10:56 am
check your sound copnfg also see if you got the mk2 in dj mode
geposted Sat 22 Mar 08 @ 10:58 am
Download VDJ 5.0.7!
geposted Sat 22 Mar 08 @ 11:01 am
A little late for the dl i was planning on doing that after this gig
dont want to do that right now
geposted Sat 22 Mar 08 @ 2:56 pm
When you say that VDJ "would not play on the second deck" do you mean the song absolutely doesn't load / play OR do you mean song is playing just no sound is coming out?
Since you say you checked the fader, I will assume the song plays just no sound.
If this is the case and If everything worked Thurs night - check your RCA connections and if your mixer has selector switches from LINE 1, LINE 2, etc check them as well (this is pretty basic, but in the rush of a gig it is easy to overlook).
GOOD LUCK.
geposted Sat 22 Mar 08 @ 10:14 pm
