Forum: VirtualDJ Skins
Topic: Numark Cue Full Widescreen 1280 x 800 Skin
Hi,
Am I missing something here guys? I am using the Numark cue widescreen video 1280 x 800 skin and it works 100% fine, but when I want to play without video I would like to use the 'full' widescreen skin. Trouble is when i select this all seems to work fine at first but at regular intervals the screen freezes for 1.5/2 seconds then frees and runs as normal. I have tried different screen resolutions on my lappy but cant get it to stop doing this
Can anyone shed any light on this? I am maybe thinking the resolution of the full skin has a part to play. Is the full skin on the download section 1280 x 800 like the video skin or different to this as it doesnt say on the download link. If this is the case does anyone have a 1280 x 800 full skin that I could download as I would maybe struggle to re-size it myself.
Thanks Lee
geposted Sun 23 Mar 08 @ 6:54 am
Are you using a mac?
No, sorry im using a P.C running vista with a 1280 x 800 screen resolution. other thing to mention. when i startup up VDJ without a controller (xp10's) I get an error saying that the vdj resolution is higher than my screen size even when it is set at the highest in control panel. I dont get this error when controllers plugged in. Weird???? Again im i missing something here?
thanks for quick reply Lee
Skyfxl?............ anybody?
One thing that can happen is that direct X can get a bit confused if you change controllers or sound cards with it still set in VDJ
you should change the settings before disconnecting the controller and closing VDJ if you know you wont use it in the next set.
Ok, I will do this in future. Anychance of getting a 1280 x 800 full cue skin anywhere to see if this stops the freezing skyfxl?
For reference, when clicking on the link in the previous post and then clicking the Mac download icon all you get is the "Add-Ons" page. Also, there was previously another working link to the same Mac skin but the skin would not work.
I wondered what the blue computer discs meant. Does that mean the skin can be downloaded for PC and Mac users.
Jimmy b
Ya but it doesn't work.
If possible, download the skin on pc Windows and copy the skin in your mac
It must be zip.
