Hi all I am a DJ french and i don't speak verry well english
I have problem whith Virtual DJ Pro whit mac et my sound cart Maya 44 usb
The probleme is i don't install my sound cart whith virtual dj
Virtual DJ no dectected my sound cart
Can you help me
With a screen is verry good for me
Thanx all a sorry for my english
Can you help me
geposted Sun 23 Mar 08 @ 9:57 am
https://virtualdj.com/blog/skyfxl/blog4912.html
I hope it makes sense.
geposted Sun 23 Mar 08 @ 10:36 am
Ok but i have no signal in Virtual DJ with my CD TimeCode and no sound
I have message
No TimeCode signal Found
Please play TimeCode Vinyls on the the turntable and try again
If it's still not working, check your cable, and the volumes of your soundcard
My cable are Ok because begun in my PC it s ok
I have message
geposted Sun 23 Mar 08 @ 10:51 am
How large is the timecode wave on Config > Sound Setup > Timecode Config
geposted Sun 23 Mar 08 @ 10:56 am
Auto config?
When i did Auto config my TimeCode is always in 0 %
geposted Sun 23 Mar 08 @ 11:00 am
can you make a screenshot?
geposted Sun 23 Mar 08 @ 12:06 pm
I have take a screen with my pc and not my Mac but i modify
My config in Mac
http://img245.imageshack.us/img245/2549/screenvu3.png
http://img528.imageshack.us/img528/8435/screenjf9.png
Virtual dj config:
http://img376.imageshack.us/img376/2966/virtualdjum9.png
My config in Mac
Virtual dj config:
geposted Sun 23 Mar 08 @ 1:41 pm
No solution??
geposted Tue 01 Apr 08 @ 3:48 am
At the moment it looks to be a issue with VDJ the only perfect card is the VV box as it bypasses the agregate wizzard.
hopefuly this can be resolved for the next versions.
geposted Tue 01 Apr 08 @ 6:39 am
Dear VDJ Friends
On my new experiencie using VDJ I'm changing my OS Plataform.
Now, I have:
Mac Powerbook G4, 1,12Ram, 867MHz, Mac OS X 10.4.11 Tyger Version
VDJ Version 5.2 for Mac
Sound Board Maya 44USB using timecodes CD and Vinil
On my old plataform (WinXP Intel) I used the same VDJ version, the same Maya44USB and timecodes, without problems , perfect !
Now ....
When i start the VDJ program and press config button, noone problem ...
Well ... when i change to use timecodes and press TIMECODE CONFIG, the VDJ not recognize the timecodes sounds (the controls are OK, I Checked This !!) and the Mac system shutdown the VDJ appl .... :( with errors .... :( :(
I love Mac, its a wonderful machine and OS but if I can't use the Maya44USB Board my best choice is to sell now the Powerbook !!
Anybody can help me ? Any thing that I can do about it ?
Directly from Brazil , Anybody Save the DJ Please !
Now, I have:
Now ....
geposted Thu 02 Jul 09 @ 9:18 pm
Can you help me
Hey guys - im having this same problem - can someone assist me?
Can you help me
geposted Fri 31 Jul 09 @ 8:55 pm
I'll post a You tube video Monday to show everyone how I got timecodes working on both my CDJ and Turntable with my macbook (latest gen) on OS X 10.5.6.
geposted Sat 15 Aug 09 @ 6:50 pm
is there a chance to post this video? cheerz
geposted Wed 18 Aug 10 @ 12:58 pm
