hi all,
wen im mixin songs to me it doesnt seem like theres not that bass that is kicking
anyway i can fix this? such as a setting i need to change or somthin i gotta do?
theres bass, but im lookin for the bass to shake the room ya no wat i mean?
thanks in advanced
thanks in advanced
geposted Mon 24 Mar 08 @ 10:01 pm
have you used the eq?
geposted Mon 24 Mar 08 @ 10:14 pm
You need a subwoofer, or bigger bass elements in your speakers.
geposted Mon 24 Mar 08 @ 10:18 pm
Norway actually knows everything...... just not all at once
geposted Tue 25 Mar 08 @ 9:15 am
yea i turn the bass up on the eq, not all the way up or else it sounds bad but i turn it mayb a lil over to the right
geposted Tue 25 Mar 08 @ 11:29 am
I find the sound distorts if I have too much gain. I always turn the gain down -8 then use other volume controls, speakers, amp, MK2 control panel. I find you get a much cleaner sound this way
geposted Tue 25 Mar 08 @ 12:30 pm
If you have the keylock on, try turning it off to see if it makes a difference.
geposted Tue 25 Mar 08 @ 12:46 pm
