Does anybody know why VirtualDJ names my External Harddrive twice, like this.
+ folder symbol, Local Disk (f:)
- folder symbol, Local Disk (f:)
then it lists all my subfolders
It does it to all the skins I tried, it doesn't effect VirtualDJ when I play, it just buggin me. Does anybody know how can I stop it from doing this. BTW using rev6
Jimmy B
geposted Tue 25 Mar 08 @ 2:01 pm
Mine changes the drive letter all the time making my playlists not work.
geposted Tue 25 Mar 08 @ 2:45 pm
Do you plug the drive into the same port everytime you setup.
geposted Tue 25 Mar 08 @ 3:13 pm
Yep
Jimmy b
geposted Tue 25 Mar 08 @ 3:17 pm
I plug mine into a powered hub, that is plugged into the same port.
geposted Tue 25 Mar 08 @ 3:32 pm
Sometimes I use a power hub which sometimes creates seperat driver. OR I mistakenly place unit in a different slot in the hub.
geposted Tue 25 Mar 08 @ 5:26 pm
That could be......hmmmm
geposted Tue 25 Mar 08 @ 5:45 pm
Hope you are using a condom.
geposted Wed 26 Mar 08 @ 5:01 pm
You made a funny and it made since when I read why you said it. Kinda like the TBS commercials "is it ok to laugh"
geposted Wed 26 Mar 08 @ 5:12 pm
