Has anyone ever had the waveforms move wayy too fast. They moved normal speed for a long time. Then something happened like a little glitch in the program and all of a sudden they started moving wayy too fast? It worked fine on my old xp laptop but would go white screen once in a while. But on my new vista laptop 1.6 core 2 duo, 1.5gb ram, the program has been solid and never crashed once....but the bpms have been shifting which seemed to go away mostly with keylock off, and clearsound off. So if i can get this problem sorted. I will actually have my first problem free virtual dj experience haha
geposted Tue 25 Mar 08 @ 2:51 pm
What version of the VDJ are you using?
geposted Tue 25 Mar 08 @ 3:12 pm
it seems you have had the use of vdj a long time, now don't take this the wrong way, if your using a crack version maybe this is just the start of your problems, you can also check to see on the waveform window if you are using the same select button ie:- 1, 2, or 3 try that and see if it corrects it
Tayla
Tayla
geposted Tue 25 Mar 08 @ 3:50 pm
You can adjust the zoom, try the slider on the left side rhythm waves display for the default skin. If it runs fine to start then all of a sudden changes something is wrong.
geposted Tue 25 Mar 08 @ 4:07 pm
It should be a legit version. I think its V 5.5? me and a guy i know are trading my serato, for his vdj and maya44 and some money. I want to try my hand at video. Ill give that a shot. I might try getting a 2nd hd for my laptop and only loading XP and VDJ with nothing else. VDJ seems to do weird stuff with vista, like when analyzing a song, if i click on any of the folders it freezes, then says something about vdj has recovered from a crash, then you push ok and it keeps going.
geposted Tue 25 Mar 08 @ 8:36 pm
it was just the zoom, i had no idea that was there :S. Thanks dudes. Finally problem free :D
geposted Tue 25 Mar 08 @ 9:39 pm
Well before you finalize the deal..you should know this. VDJ licenses are not transferable. So, you would not be able to upgrade at all. With your own license of VDJ you are eligible for lifetime free upgrades. Some food for thought.
geposted Tue 25 Mar 08 @ 9:47 pm
but what if he just gives me his username and pass for his account here? i dont really care if its under my name, as long as i can get the updates? if not then i might as well just sell the serato and buy vdj brand new?
sorry for the 2 diff usernames, i forgot my pass, so i made a new account for the home computer.
geposted Tue 25 Mar 08 @ 10:18 pm
That is what I would do in your shoes.... :-)
geposted Tue 25 Mar 08 @ 10:20 pm
there is a 1 ,2 ,3 all of them are different views of the wave form. just click and go.. its all good...
geposted Tue 25 Mar 08 @ 11:06 pm
