I'm using a dual boot system with 2 hard drives and a copy of vista on each drive, one for normal use, one for VDJ.
I'm trying shrink the partition that VDJ Vista is on, but It won't let me shrink as much as I want even though there is room.
I've turned of page file, system restore on that drive, stopped error reporting, performed disc clean up and defragged. There seems to be some file that can't be moved during a shrink which is stopping me.
Any thoughts?
Gary
Any thoughts?
Gary
geposted Wed 26 Mar 08 @ 10:22 am
you should hove done this befor you put any software on the HD
geposted Wed 26 Mar 08 @ 11:07 am
Ok, best I rephrase that, any helpful ideas? lol
I've read that some third party disc partitioner's will do what Vista partitioner won't. Is this correct?
Gary
Gary
geposted Wed 26 Mar 08 @ 11:18 am
I too tried to shrink with no luck using Vistas manager. Try Partition Magic, it may work and if it does let me know:)
geposted Wed 26 Mar 08 @ 2:30 pm
Paragon partition manager did it. No problems at all, hope that helps.
Gary
Gary
geposted Wed 26 Mar 08 @ 4:56 pm
Cool thanks for sharing as I need to do mine:)
geposted Thu 27 Mar 08 @ 3:41 pm
