Hi all, im using virtualdj and timecoded cds but also I use conventional CDs for playing some other songs my question here is what can I do to put a blank screen or something when im not using virtualdj because the videos left on the machine displays the last frame or starts moving weird (because music is playing and VDJ tries to interpretate the time code) so any suggestions here?
Thank You
Thank You
geposted Thu 27 Mar 08 @ 5:14 pm
You need the pro version, then you will be able to put all kinds of different graphics, and video clips on the screen, when you are only playing audio. You can even have it play automatically.
geposted Thu 27 Mar 08 @ 5:22 pm
Ok I bought the professional version now how to activate that feature? thank you
geposted Thu 27 Mar 08 @ 11:29 pm
Ok get this file here
http://www.virtualdj.com/addons/download.html?addon_id=4207
These are the Sonique graphics that move with the music (audio).
Extract these files to My documents, Virtual dj, Plugins, Video Effect folder.
In Virtual dj go to CFG, click on the video button, look towards the bottom of that and you will see something to the regards: Use while no video is playing, select Sonique from the dropdown.
You are almost there.
In VDJ click on your effects section, then click on Video effects, find Sonique, there you will see an "Open" and a "Slideshow" button on the right, click "open" and find the folder in my documents you put the sonique files, double click one of the .svp files and you should then see your sonique graphics playing on your screen.
If u still have questions just ask:)
Also Welcome as a Pro user, there are a ton of skins and effects u should take a look at in the downloads section.
geposted Thu 27 Mar 08 @ 11:49 pm
Ok thank you very much one more question I mix a lot of vid and have a 22"inch widescreen LCD, so wich skin you think is the most appropiate for this size of monitor? ty so much
geposted Fri 28 Mar 08 @ 1:10 am
What is ur resolution set at??
geposted Fri 28 Mar 08 @ 1:27 am
welcome to the community Neo
if you need some extra bits and pieces for clipbank i have one or two clips you can have if you like, just pm me with your email
Tayla
Tayla
geposted Fri 28 Mar 08 @ 1:50 am
Thank you again my resolution is set to 1680x1050 in main screen and 800 x 600 in secondary
Also I have some vids i made my own with the logo of the nightclub and stuff can I make them play while theres only audio playing ? ty
geposted Fri 28 Mar 08 @ 1:57 am
yes, activate clipbank
geposted Fri 28 Mar 08 @ 2:08 am
