hello I has now everything attached to maya the etc., but I have all 2 sounds of the TTs only on a channel. what can lie?
geposted Fri 17 Dec 04 @ 7:00 pm
The problem can comes from your cracked version 2.04 or 2.06...
We don't support a cracked version.
geposted Fri 17 Dec 04 @ 7:26 pm
no i have the demo version
geposted Fri 17 Dec 04 @ 7:27 pm
but the demo version is 0 days avaible. can it therefore are`? it wants to only know that it is appropriate if I for full version buys wants I to have all this functioned
geposted Fri 17 Dec 04 @ 7:31 pm
Full version and maya44usb are working very well with one or two turntables.
geposted Fri 17 Dec 04 @ 8:31 pm
ok i buy the original. and then all work?
geposted Sat 18 Dec 04 @ 3:25 pm
POSSITIVE +++++++++++++
geposted Sat 18 Dec 04 @ 5:26 pm
Come on as a full user; it worths the price trust us.
This is the best PC-DJing software. It works very well.
geposted Mon 20 Dec 04 @ 5:34 am
in the full version
does it have the
Low Latency Timecode" configuration (the image with turntables, at the bottom of the list).
because, im using the demo and it doesnt have it, it only goes as far as the dj hercules
does it have the
geposted Fri 24 Dec 04 @ 2:50 am
I think yes that I don't have TC vinyls so I cannot answer you at 100%.
Maybe someone else ?
geposted Fri 24 Dec 04 @ 9:20 am
thebachelor: stop using a bugged cracked version, and buy a legal full version
geposted Sat 25 Dec 04 @ 5:57 am
