I set a shortcut to reduce the bass level
I set bass and -1500 plus momentary
But when i release the shortcut key, the bass level back to another position, not to the original..
geposted Thu 17 Jul 03 @ 1:20 am
This is a small glitch in design. It could be made to work like you said.
Currently the +-value doesn't seem to work with momentary enabled.. If you put value like 3000 and enable momentary, this will have same effect as when you have bass knob at +-0, and then doing momentarily +952..
Problem with the current way it works is that you can't make a relative change.
geposted Thu 17 Jul 03 @ 8:16 am
to get -1500 currently, you have to do math like 2048 - 1500 = 548 .. So put value 548 and enable momentary, don't put any + or - in front of 548.
geposted Thu 17 Jul 03 @ 8:18 am
Yes, if your bass level is under 1500 and you substract 1500 maybe the bass level go down to 0 and when you release the key go up to 1500:
exemple:
level: 1000
key -1500 -> -500(impossible so 0)
release +1500 -> 1500
So before 1000 and after 1500. I may be wrong, but as said before, you'd better to set a temporary value to be shure that you don't go over limits (0 - 4096) if you use big values like 1500.
If someone can confirm or give an opinion...
exemple:
level: 1000
geposted Thu 17 Jul 03 @ 8:47 am
