hi,
the problem is that we only have 2 tt's at the club and i use vdj while the other guy uses serato. i was wondering if it was possible for me to split the white and red rca wires (with y-splitters) of a tech 1200 so that i can put two inputs into my soundcard and another two into his sound card.
i know the mixer needs 4 channels. but i just wanted to know if there would be a decrease in quality, and if it was even possible..
thnks
thnks
geposted Mon 31 Mar 08 @ 12:22 pm
I did the same thing for my home set-up and haven't found any problems with reading the timecode using VDJ or Serato.
I use "y" adapters to split the turntable signal between the two soundcards. I didn't want to keep plugging and unplugging them in and out wearing them out.
geposted Mon 31 Mar 08 @ 12:40 pm
NO ! Man Its Not Possible .. I Tryed The Same Thing At Home Didnt Work !
geposted Mon 31 Mar 08 @ 1:42 pm
You only need to buy Y adapters. I have cables that already include a splitter.
geposted Mon 31 Mar 08 @ 4:08 pm
ok so it is possible?? why did one person say no? it works for splitting the signal between digital and analog (as in cstoll's blog) isnt it the same for 2 digital? i more concerned about quality lose than anything...
also, arent 'y adapters' the same as 'y splitters'? one female on one end and two male on the other... correct?
geposted Mon 31 Mar 08 @ 7:53 pm
