Numark DMC2 & CM200USB mixer OR Denon DN-hc4500 usb midi & denon DN-x500 Mixer..........................anyone know the good and bad about both ..........a comparison...........im planning on buying Numark or denon.
geposted Mon 31 Mar 08 @ 3:08 pm
Why not buy the professional computer dj in a box package it contains the full Cue , cm200 and a DMC2 at a discount price for purchasing together.
As you will need a full pro edition of VDJ/cue to use either.
geposted Tue 01 Apr 08 @ 6:38 am
here we go again .... advice huh ? do you want good advice or just advice ??
here's useful advice ...... never shout out the wrong girl's name in the throes of passion ..... there, good advice
geposted Tue 01 Apr 08 @ 9:23 am
Having owned both of the setups you speek of, I prefer the Denon.
More rugged. Better feel. Better quality buttons and faders.
geposted Tue 01 Apr 08 @ 1:00 pm
does anyone know if the Numark DMC2 & CM200USB mixer and the Denon DN-hc4500 usb midi & denon DN-x500 Mixer are like the mk2, that when u move the crossader or pitch etc. it also move in virtual dj?
geposted Wed 02 Apr 08 @ 5:38 pm
The dmc2 has a crossfade button but both of those mixers do not have midi support if you want somthing like that you should consider a full midi mixer or just a controler.
geposted Thu 03 Apr 08 @ 3:34 am
do u know of any rackable controllers with a midi support?
geposted Thu 03 Apr 08 @ 2:56 pm
@ chuck
that mean i shouldn't mention the twin sister thing then...
oops, sorry scribe
oops, sorry scribe
geposted Thu 03 Apr 08 @ 3:21 pm
You are joking? my buttons on my DNX500 packed up after on the 13th months, It was the cue and headphone on and off buttons that went.
Get the Numark gear out off the two.
geposted Thu 03 Apr 08 @ 5:24 pm
any one else has more advice?
geposted Thu 03 Apr 08 @ 6:29 pm
what ever gets the most positive post is going to be the one I'm getting.
geposted Thu 03 Apr 08 @ 6:52 pm
no one else?
geposted Wed 09 Apr 08 @ 3:02 pm
Read some reviews and make up your own mind that way is best.
geposted Wed 09 Apr 08 @ 3:23 pm
The Denon HC4500 and the Denon X500 is the way to go. You are using only 1 usb port. The Numark CM 200 usb mixer uses up 2 usb ports and the controller uses 1. All together you are using 3 ports. The denon X500 is a better mixer and the faders dont leak like the numark. there is no comparison between numark and denon. Denons are more rugged and durable and better made.
geposted Wed 09 Apr 08 @ 7:08 pm
