Hello! I have a little problem and a doubt to! I have a pc that has the following caracteristics:
-P IV 2.4 GhZ computer
-800x600 SVGA video
-4.1 DirectX compatible soundcard (Audigy)
-60 MB free on the hard-drive
-Geforce 4 nvidia
Has you can see the pc isn´t bad, altough I the monitor is poor and doesn´t mach the minimun requirement that is needed in order to run virtualdj, or am I wrong?
I have test virtualdj with the 800 x 600 screen (or skin) that is similar to Atomix that I bought and so I am a full user and the screenshot of Virtual DJ taht has the resolution 1024 x 768 has better and more fuctions! Im I right? the 800 x 600 in order to work with all the functions we have to use shortcuts, isn´t it true? Or has the 800 x 600 less fuctions?
Please help-me because I´m ready to buy virtualdj because it´s real good but I must know this resolutio problem!!!
Has the 800 x 600 screen less visual fuctions that 1024 x 768 or doesn´t has it at all?
-800x600 SVGA video
-Geforce 4 nvidia
geposted Thu 17 Jul 03 @ 1:52 am
have you tried setting the screen resolution?
go to the desktop and right click anywhere and click on properties (on the menu that opens) and it the settings tab change the "Screen Area" to 1024x768
geposted Thu 17 Jul 03 @ 1:58 am
Hi, I had the exact same problem as uve got now. All i did was convert the 1024x768 skin to 800x600, and hey presto it workz. All u need to do is edit the file in a image editing program like paint shop pro and convert it to 800x600 keeping the aspect ratio.. That should do it 4 ya!!
Good Luck..
Dj Dark Storm
Good Luck..
Dj Dark Storm
geposted Thu 17 Jul 03 @ 2:08 am
Hello again! Dj Dark Storm I tried to do what you said! I converted the advanced skin to the 800 x 600 with the paintshop pro and it didn´t work! the program still opens the 1024 x 768 skin! How have you done it?
Please somebody help! My monitor just support in the max the 800 x 600 resolution!
geposted Thu 17 Jul 03 @ 10:02 pm
buy a new monitor........... lol.........
geposted Sun 20 Jul 03 @ 8:15 pm
you have to resize your 1024x768 picture. warning just resize the width to 800, do NOT change height to 600. it has to be done by your image editing software.
then you must convert the corresponding xml file... either waste 1 hour editing, or go to http://musiqman.free.fr and download my converter :)
geposted Thu 31 Jul 03 @ 9:06 pm
