can someone help.....
i can not rip my video's . Im useing promo only i don't think this matters. i can not find how to rip a CD ....
can some one help thanks...
geposted Tue 01 Apr 08 @ 1:24 pm
Click my name to the left to go to my blog where you will find tutorials
geposted Tue 01 Apr 08 @ 3:03 pm
Oh, that reminds me. Hey Tophouse, I have a DVD of the group Cameo and I can rip the video but no matter how I do it. It still gives me a heavy distorted audio. The video is perfect but the audio is so fuzzy like the signal won't go through. I tried checking / unchecking audio streaming.
geposted Tue 01 Apr 08 @ 3:24 pm
buy VJ Ripper from www.clubdjpro.com
geposted Tue 01 Apr 08 @ 5:37 pm
out all my videos this is the only one that does it. At first I thought it was a security problem but why this video compared to the others.
geposted Tue 01 Apr 08 @ 5:42 pm
Don't BUY anything! there's plenty of good free rippers out there! If you're having trouble with the audio stream it can be a couple of things, incorrect codecs is one, if you're doing a lot of ripping the AC3 one is a must, again free. BUT if you're getting like just a static noise, normally it's because you have a multi stream format vob and you're playing the wrong audio stream. In dvddecrypter where you select what streams you want, is it showing more than one audio stream? If so, try eliminating the unwanted one/s and that should do it.
@FatKats
It just happens sometimes, when you rip as many vids as i have you will see it a few times and you just work around it when it happens, anyone else on here that rips a lot will say it happens to them sometimes also, just one of those things.
@FatKats
geposted Wed 02 Apr 08 @ 5:35 am
