hello,
I would like to know, if there is any possibility, to increase the number of 12 samples(jingle/loops),
at the same time, by skin window, instead of loading, anytime you need a new one ????
Otherwhise, could we associate different groups of 12 samples, according to the playlists you saved??
Thanks, and regards,
RB2005
geposted Sun 19 Dec 04 @ 9:59 am
Not at present.
Maybe in the future releases. Post a suggestion in the "new features" section for it.
(Make a search; it has already been asked)
Clax
Clax
geposted Mon 20 Dec 04 @ 5:38 am
Hi Clax,
Thanks, for your help.
As a newcomer, I`ve not checked, all the technical situations, found at the Forum.
Meanwhile, could you give me an hand, concerning the topic:
EARPHONE AND MIC CORRECT USE, because until now i had not find a solution.
Thanks in advance,
Au revoir, et a bientôt,
RB2005
Thanks in advance,
RB2005
geposted Mon 20 Dec 04 @ 10:34 am
What are your pc specs?
geposted Mon 20 Dec 04 @ 11:07 am
hello need some answer i bouht a dj console with virtual dj and i can`tfind the serialnumber of mei box cd or everything where can i find it
geposted Mon 20 Dec 04 @ 12:35 pm
There is no serial number provided with the Console. Only users that bought the full version get a serial number.
geposted Mon 20 Dec 04 @ 12:37 pm
Hi DJ Coco,
My PC conf. is : (notebook - 17" wide screen), P IV 3.06 Ghz, Ram 1.00 GB.
(C-Media 3D audio) Xear 3D audiocard.
SPIDF- 5.1 out.
Please, check also at the TOPIC :" Headphones and Mic correct use", my last report, to Clax,
Thanks, and Regards,
RB 2005
SPIDF- 5.1 out.
RB 2005
geposted Mon 20 Dec 04 @ 11:39 pm
