Hey guys. I'm going to get my gear within these next few days and I was just wondering if you have any recommendations for websites to order off of. I don't want to end up fighting for my equipment because it's taking weeks to arrive or something. I'm looking at the numark professional computer dj in a box package from zzounds.com. (http://www.zzounds.com/item--NUMPCDJ) Has anyone had any bad/good experiences with them? Any advice at all would be great thanks.
geposted Fri 04 Apr 08 @ 5:00 am
Hi where are you located?
It is a great , package for a mobile DJs , who want a simple setup process with good results each time , it is made up of :
DMC2 CONTROLLER
This is Numark's flagship rack-mount DJ software controller, featuring a rugged metal frame that can be used in a 3U rack–mount setting or as a tabletop unit. The DMC2 has a form factor based on CD players such as the CDN95 and CDN35, which allows mobile DJs who are comfortable with rack consoles to quickly and easily add the power and versatility of software–based mixing to their arsenal. No assignment of software parameters for the DMC2 is necessary – simply connect the controller to a laptop with a USB cable, enable the CUE configuration screen, and watch the virtual controls respond to the DMC2's actions.
CUE 5 DJ SOFTWARE
Numark's club tested, professional–level DJ software and your personal computer work together to create the ultimate mix. Monitor your mix through headphones and visually on your computer screen. Output your masterpiece to a club's sound and video system. Use CUE 5.0's built–in broadcast functionality to podcast on the web. Every DJ can also be a VJ using CUE 5.0's built–in video transitions and effects. CUE 5.0 supports CD+G formats for a quick and easy Karaoke setup. You can easily mix, scratch, juggle, interchange and sample audio and video files. Version 5.0 includes loads of new enhancements including FreeFrame plug-in compatibility, Smart Database management, and a powerful new Global Search function.
CM200 USB - FIVE CHANNEL PRO DJ MIXER AND USB AUDIO INTERFACE
The CM200USB is a 5–channel mixer that utilizes the design and features of our famous CM200 mixer and adds the power of USB I/O, allowing you to play audio files from your Mac or PC. DJs can even record live performances onto a laptop or desktop, making the CM200USB perfect for club or studio work. The CM200 USB also includes master balanced XLR outputs (with Record and Zone), a 3–band EQ on every channel, effects, and many other features that will keep your mixes energized for years to come. The Numark CM200USB is a powerful DJ and studio tool, linking traditional input options with the power and versatility of USB.
PHX DJ HEADPHONES
PHX premium headphones incorporate an isolating, closed–ear design with 50mm neodymium magnet drivers, for professional–quality high output. The PHX package comes with 2 styles of interchangeable ear pads and 3 types of cables. A special 2–part ear cup design incorporates a rubber/silicone casing for a comfortable and secure fit that rests between ear and shoulder while cueing. PHX headphones fold up for storage and come in a premium hard carrying case. The PHX is the new standard in pro DJ headphone technology, providing the cleanest, loudest sound for the most fatigue–free and durable performance.
DMC2 CONTROLLER
CUE 5 DJ SOFTWARE
PHX DJ HEADPHONES
geposted Fri 04 Apr 08 @ 6:28 am
I used Prosound and never had an issue with them.
www.pssl.com
www.pssl.com
geposted Fri 04 Apr 08 @ 11:44 am
And of course you will be purchasing VirtualDJ first..............
geposted Fri 04 Apr 08 @ 12:01 pm
It comes with full version of cue jim
geposted Fri 04 Apr 08 @ 12:47 pm
yeah Jim... it comes with... sheesh. ya noob
geposted Fri 04 Apr 08 @ 1:00 pm
Oh go Nair your palms.... I got your back Jimmy..
geposted Fri 04 Apr 08 @ 1:13 pm
I'm located in Los Angeles. I'll take a look at the pssl website. Thanks.
geposted Fri 04 Apr 08 @ 3:04 pm
and the cavalry's just arrived....
geposted Sat 05 Apr 08 @ 5:39 am
