if my screen gets shut, or someone presses the screen closed sensor. The only way i can get the display to show back up, is by pressing control alt delete a bunch of times, the power button a bunch of times, then the screen closed sensor a bunch of times? Anyone had this happen? Im seriously thinking of busting that sensor off
geposted Fri 04 Apr 08 @ 1:36 pm
Not sure what you mean....
Screen saver? or power management for screen? You can turn both off
geposted Fri 04 Apr 08 @ 5:37 pm
power management is set to screen always on, screensaver is set to off.
Like if i close the lid on my laptop. Then open it. The screen does not turn back on, it does sometimes, and not others. This problem is more if i just touch the button that gets pressed by the screen being closed by accident.
In order to get the screen to turn back on. I have to hit control alt delete a bunch of times, then the power button a bunch of times, then open and close the lid and it will come back on to the lock screen.
geposted Sat 05 Apr 08 @ 4:31 am
That is most likely a video driver problem, try to update. Turn off in Power Management the Lid to "nothing".
geposted Sun 06 Apr 08 @ 10:14 am
