hello, i was just using my vdk software and the bpm grid suddenly slowed up. i cannot fixed it, tried resettin cpu and program. the songs play at the correct speed but the grid is moving veryyyyy slow. anyone ever have this problem>? Please help me, i have a gig tonight!!
geposted Fri 04 Apr 08 @ 3:22 pm
Did you accidentally hit the slider button on the grid which will stretch / shrink the grid. The 1,2,3 buttons make changes and the slider also does the same thing. Check there first and let us know.
geposted Fri 04 Apr 08 @ 3:53 pm
yea im sure it is something i did by mistake. i am using the viinyl scratch skin. is there any button i can press to make it return to normal. i believe i did stretch the grid out
geposted Fri 04 Apr 08 @ 3:59 pm
you messed the zoom up
geposted Fri 04 Apr 08 @ 4:00 pm
when i press 2 , only thing that happens is a 2 beat loop is set
geposted Fri 04 Apr 08 @ 4:02 pm
press #2 on the skin <-----
geposted Fri 04 Apr 08 @ 4:04 pm
the only numbers on my whole entire skin is the numbers that represent loops
geposted Fri 04 Apr 08 @ 4:06 pm
can someone please help me? should i reinstall the skin
geposted Fri 04 Apr 08 @ 4:26 pm
try a different skin....change the magnification then change back to your regular skin...
geposted Fri 04 Apr 08 @ 4:27 pm
the songs are even staring slower. the grid is showing the following pattern 1..2..3..4 instead of 1234.1234.1234.
geposted Fri 04 Apr 08 @ 4:35 pm
What are your system spec? How many applications do you have running? Lap top or desktop? Did you turn off the anti virus? Are you connected to the internet? Have you tried uninstalling and re-installing VDJ?
geposted Fri 04 Apr 08 @ 4:48 pm
yes i have tried all of those things. i must say the new sound engine in 5.07 sounds nice. i just updated to the latest version of vdj, checked my soundcard settings, no internet on, the anti virus is turned off. i was running vdj in internal mode. i am using a HP laptop 2046mb ram 1.73ghz windows vista
geposted Fri 04 Apr 08 @ 10:24 pm
take a screen shot and post it.
geposted Fri 04 Apr 08 @ 10:36 pm
geposted Sat 05 Apr 08 @ 12:48 am
Move a cursor on the waveform and spin the mouse wheel to zoom.
And btw, you cannot link an image from your google mail, unless it's publicly accesible.
Code for image should look like this:
geposted Sat 05 Apr 08 @ 3:38 am
problem fixed. thank you.
geposted Sat 05 Apr 08 @ 9:50 am
