Is it possible to give the EQ'S (High, mid, & low) greater 'kill' range?
Thanks for everyone's input.
FLeX
FLeX
geposted Fri 04 Apr 08 @ 8:53 pm
I use Virtual Vinyl and when I turn down any of the EQ knobs they are full kill. I assume VDJ is the same. What do you mean by a 'greater kill range'? By 'range' do you mean having the ability to set the kill to full or slight or somewhere in between? In other words, are you looking for the ability to customize the amount of kill the EQ's have? Because at the moment it seems like they are full kill to me.
geposted Fri 04 Apr 08 @ 11:21 pm
The built-in EQ cannot be adjusted. It would be good to have the cutoff frequency and filter order
parameters for HPF & LPF in settings, as HPF cuts way to high in my opinion.
But it is not a priorty feature at the moment.
geposted Sat 05 Apr 08 @ 3:56 am
FLeX
FLeX
There's a new sound effect plug-in made by TexZK which does what you wish; now it isn't show because that has some little problems that the developer have to still fix up
geposted Sat 05 Apr 08 @ 4:38 am
Eric,
You hit it on the nose. The ability to adjust the parameters and frequencies.
I believe that would be a great additional feature.
FLeX
FLeX
geposted Sat 05 Apr 08 @ 7:49 pm
Know what feature i would love...
Is when you hit a kill switch...the EQ level know acts as the range...it would make EQ mixing AMAZING...!
For example...hitting the Low Kill would and turning the knob would affect the range of the lows that are cut.
geposted Wed 18 Jun 08 @ 7:41 pm
I like that...sounds user friendly.
geposted Tue 01 Jul 08 @ 8:20 am
Wishes for 5.1 Mac, for professional use:
1- "Searches"same as iTunes.
2- Ability to update Virtual DJ automatically whenever changes are made in iTunes.
3- Ability to memorize sorting until you close the program. Example: open "House" (genre) list and sort Artist A to Z. Do the same with "Disco" and then return to "House". You will see that your list
with House Music is no more sorted as before.
4- Ability to send BPM values to iTunes library.
5- Add the "Grouping field".
Elvert B
Rio de Janeiro - Brazil
Thanks,
Regards,
DJ Elvert B
Elvert B
Thanks,
Regards,
DJ Elvert B
geposted Tue 01 Jul 08 @ 10:15 pm
Wrong topic dude.
geposted Wed 02 Jul 08 @ 1:50 am
