2 questions about Virtual DJ.............
How do you configure the software to automatically clear the deck after the song is finished playing? Most other programs have a checkbox that configures this option, but I can't find it in Virtual DJ.
How do you configure the odometer to always show the "remaining" seconds? It always goes back to "elapsed" after I close the software.
geposted Sat 05 Apr 08 @ 1:14 pm
right now there's no option to clear the decks automatically,
but you can create a shortcut
it's called "unload"
regarding the timer
it will always go back to default, elapsed
try to find a skin which displays both, elapsed and remaining
cheers,
matt
regarding the timer
cheers,
matt
geposted Sun 06 Apr 08 @ 1:08 am
They're a couple of skins that I know off and use that have a unload button on the skin,
the first is Cioce Cue skin v1.5 (you can find it in the Cue variations) and Formats Mixlad Skin.
geposted Sun 06 Apr 08 @ 10:06 am
