When I used to save playlists in VDJ, I was able to browse through folders to select the folder that I wanted to save playlists in. Now VDJ does not let me browse folders, it just asks for a playlist name... Where on my hard drive are these playlists being stored? Can I set this to go back to my usual "C:\Program Files\VirtualDJ\playlists" location? I'm asking because I renamed one of the playlists, but instead of renaming it, it disappeared. I don't know where it went, if anywhere...
Thanks!
Thanks!
geposted Sat 05 Apr 08 @ 6:21 pm
my documents ..maybe..try there..vdj stores precious info on my documents
geposted Sat 05 Apr 08 @ 6:42 pm
My Documents -> VirtualDJ\Playlists is where all Saved... playlists go.
My Documents -> VirtualDJ\Tracklisting is where all Session Saved... playlists go.
These are set by default based on the Home Folder being My Documents for compatibility between Vista and XP.
geposted Sun 06 Apr 08 @ 1:07 am
Oh there they are! Perfect, thank you!!!
geposted Sun 06 Apr 08 @ 11:19 am
