Forum: VirtualDJ Plugins
Topic: Izotope Plug-Ins
McQ714PRO InfinityMember since 2003
Just thought I'd post a recent discovery I had with the use of VST plugs. I have Izotope's Ozone, Trash, and Spectron plug-ins and decided to try using them in VDJ. They seem to work just fine which is somewhat a shock to me comparing file size difference of these to the other plugs that come with VDJ. Just copy the .dll file from your VST folder to the VDJ plugins folder.. you can also use multiple instances with different settings on each with the simple renaming of the .dll file before pasting the second instance in the plugin folder. Rather simple i know but i never realized it until today that this was possible.
geposted Sun 06 Apr 08 @ 2:22 am
