I know this was discussed before but I could not find the thread.......
How do I get ONLY the songs/videos on drives CURRENTLY attached to the computer to show up in the browser? I have been doing a lot of file rearranging and consequently file tranferring to various drives which at some point were all connected to the computer when VDJ was running and so now even when I only have the computer with the main internal drive operating I get like 10 copies of everything showing up in the browser. Is there a way to change this?
geposted Tue 08 Apr 08 @ 12:46 am
Go to Config-Browser and do a check on the drives where you have files and then perform a clean. That should get rid of any files that once where in a particular location but that are not there at the moment.
Hope this helps. :-)
geposted Tue 08 Apr 08 @ 5:02 am
Correct. If you have been doing several move/copy operations and re-organizing your music. You should utilize the Check, Clean and Fix utilities on your respective drive databases in the Browser tab.
Good advice - vidanes!
geposted Tue 08 Apr 08 @ 8:01 am
