Forum: Wishes and new features
Topic: sampleboards and more effects
hi i think u guys should make a sample board loader which means that u could save different setups of samples.
ex if i have a samplesetup with drum sound only and then suddendly i wanna use a different sampleboard i simply puch a button and then i load like a playlist.
ofcourse u could save sampleboards.
just a idea... but i would like it.
u should also have 3 more effects slots and mabye u could do the same thing to the effects like the sampleboards i mentioned earlier.
fill in if there is something more u want
geposted Mon 20 Dec 04 @ 7:57 am
It would also be nice if u guys could put in a loop tool in the sample section.
And a repeat button would not be that stupid.
Also if i could put effects on the samples via the keyboard like if f is fx 1 g is fx 2 and h is fx 3.
then if u wanna put fx 1 - 3 on sample 1 - 12 it would be like this.
F + F1 puts a effect on sample slot 1
I would like that a lot but it might not be possible
ask anything u want
Eq´s to the samples like the uc33 would not be nice too
I like the first idea very much - and it's definately not hard to implement, so I would also love to see that in some of next updates.
A plugin to repeat the song is available for Profesional Edition User only. For samples, you can do a loop to repeat the sample.
You can do a lot to your samples just reload them in the decks off your browser then just resample the effected sample(you may do this several times before you loose sound quality)
Andre
