So after talking to Dell I can now do vidz without any issues using my laptop! However after I play a video or while my last video is playing and I load a nonvideo it loads really slow but if I declick activate in the config mp3s go back to loading fast.
why is that? when I decheck activate my laptop gives a slight audio hiccup.
Thanks for your reply.
geposted Tue 08 Apr 08 @ 10:45 pm
have that same issue with our desktop at the club (minus the hiccup) even with a really good video card upgrade. doesnt really cause problems per se, its just annoying. anyone else got that problem?
geposted Tue 08 Apr 08 @ 10:51 pm
cstoll wrote :
Have you downloaded the Registry Tool and checked off the SpeedLoad option ?
I just did, checked it, and applied so i'll see if that works. :)
Thanks CS.
geposted Wed 09 Apr 08 @ 12:46 am
It worked! Issue solved!
geposted Wed 09 Apr 08 @ 1:15 pm
what is the point of speedload then? and if it is hindrance why is set to default being on instead of off.
I had this exact same issue for a long long time & just now hearing about the solution.
geposted Wed 09 Apr 08 @ 1:54 pm
alrighty then...
geposted Wed 09 Apr 08 @ 4:07 pm
Sorry guys, just to clarify, should the box be ticked or unticked? I have a box issue, always have, they cause me problems!
Gary
Gary
geposted Wed 09 Apr 08 @ 5:08 pm
Checked activates the Speedload ability ( less cautious load / faster ) -- Unchecked de-activates and uses a more cautious loading.
geposted Wed 09 Apr 08 @ 5:47 pm
Cheers :)
geposted Wed 09 Apr 08 @ 5:59 pm
