why is this??? My cdg files will not load in to 5.7 why is this??? Is there some kinda codes i need to put in? I love virtual dj but help me with this cause I can not up date my virtual till i figure this out. Also why is the key changer so bad is there a way you guy can come up with a new one I use it often for my drunks lol and it sounds like crap why???? please help me.
geposted Thu 10 Apr 08 @ 3:29 pm
Do you mean that they will not load into the browser? If so, check that "show karaoke" is ticked in the the browser's "bulleye." If you mean that they will not load into the decks, make sure that the cdg and mp3 names match exactly.
The key changer quality, I think, is proportional to the bitrate of the mp3. If you are running lower than 192Kbps, it sounds like crap. My karaoke is 128, and I have the same trouble. Try the key changer on a higher bitrate file and you'll hear the difference.
geposted Fri 11 Apr 08 @ 9:28 am
