Hi Guys, I'm in a bit of a panic! I just moved all my songs onto an external drive and shortcutted them again and I've lost almost all my cues and bpms!!! What happened!? What can I do? Please help ASAP as I've a gig tonight!!!!!
Rory
Rory
geposted Sat 12 Apr 08 @ 10:53 am
Here is what I would do, copy/paste your .xml database found in C:/My Documents/VirtualDJ. There are two folders VirtualDJ Database v5.xml and VirtualDJ Database.xml, paste both of those onto your ext HD. That SHOULD give you want you were looking for. Lets us know if that works..
geposted Sat 12 Apr 08 @ 11:12 am
Yep you need to move your database .xml aswell as your files.
The database needs to be on the same drive(s) as your files are on, it is designed like that.
geposted Sat 12 Apr 08 @ 11:16 am
Thanks for the quick replies guys! I have copied over Virtual DJdatabase.xml but theres not one called version 5 anywhere! So it hasnt worked yet! Any ideas?
geposted Sat 12 Apr 08 @ 11:29 am
Sry, found both folders an copied them in. Still hasnt worked though!! And its mainly my two most important folders! Hip Hop & RnB and Club House!! This is killing me!!!
geposted Sat 12 Apr 08 @ 11:34 am
Open VDJ, go to the config tab..click it. The select browser, in the bottom window in the drop down select the drive (I.E. E Drive) tick check, then clean, then fix. See if that does the trick.
geposted Sat 12 Apr 08 @ 12:13 pm
No use, tried everything! Been at it all day. Even had Bagpuss helping me over MSN and still no look! I can't believe VDJ let me down! 3 years of work gone!! I'll have to start scanning all my songs again tonight, and spend the next few weeks doing all my cue points again. I'm absolutely GUTTED over this.............
geposted Sat 12 Apr 08 @ 2:14 pm
Where in EXT drive did you put the .xml files?? In a folder or stand alone? It should be stand alone..also..you might need to reboot once that is done...
geposted Sat 12 Apr 08 @ 2:25 pm
stand alone and i have rebooted! twice! its weird cos theirs some but not all!
geposted Sat 12 Apr 08 @ 2:33 pm
next time use vdj to move your music and it will keep the info
geposted Sat 12 Apr 08 @ 2:51 pm
To solve your problem without having to scan your files again, you should have moved the files back to where they were in your internal drive. Then use the files operations ("copy to" or "move to") in Virtual DJ to copy or move your files. This would have ensured that Virtual DJ copies your database files to your external drive.
geposted Wed 16 Apr 08 @ 9:40 am
