Forum: VirtualDJ Skins
Topic: Resize Skin
Hi Guys,
I'm in need of some help. I would like a skin resizing to 1280x1024, but only by enlarging the record case/browser area, leaving the players and controls the same size as they are in the 1280x800 version.
I've downloaded the resizing app but can't seem to work it properly (that's me being useless, not the app btw!!)
Any help or volunteers guys? Thanks
geposted Sat 12 Apr 08 @ 12:16 pm
No, it's not you,
I've never got it to work either.
About which skin it is?
I would like to resize mini scratch 1280x800 to 1280x1024. Thanks
Sorry i tried to resize it but my screen is only 1280x800 so i have no idea how it looks since i cant test it. If you open the XML you should change the 800 to 1024, then after that you will probably have to extent the browser plus the lower graphics.
OK I made him(it), where may I send him(it) to you?
click on my blug for my mail
if you want to send it to me i'll check it out and add it on the download page.
check pm's
check pm's
ok look for add on
Thanks Pasco, i have pm'd you.
