Would like to look into code,(esp. the delay and flanged loop-out, and maybe the vocal/ a cappella ) and would like to work with some of the sources available...I have been referred to you as you are the whiz in the dept. Any help with access 2 em would be greatly appreciated.... I also disabled my p.m option and would re-activate it if I found out how, thanks!
geposted Tue 15 Apr 08 @ 2:19 pm
All experienced users can access source-code for plugins, so maybe Cel will upgrade you.
At least I think he'll let you see the code, as soon as he reads ;)
geposted Tue 15 Apr 08 @ 5:14 pm
