Is my soundcard suppose to be detected in the configuration menu.....because after i select external mixer, i selected asio because there was no detection of my u46dj souncard, nor is it listed in the next menu. Basically i dont want to end up buying the tcv's to find that is doesnt work. please help
geposted Tue 15 Apr 08 @ 2:26 pm
Basically, if your not a licensed Pro user of VDJ time code only works for five minutes.
geposted Tue 15 Apr 08 @ 2:31 pm
Thats the way U46DJ is set up in VDJ...select ASIO driver, and down select u46dj 1,2,3,4,5. It works good with TCVs.
Dont forget to register VDJ, as TearEmUp say, it will only work for five minutes.
geposted Thu 17 Apr 08 @ 3:15 pm
