Does anyone know if you need to buy TWO of the Xp5 MIDI controllers (if you already have a multichannel soundcard)? Or can I use one, and use that to operate the separate virtual decks one after the other?
geposted Wed 16 Apr 08 @ 9:23 am
I think it is possible to program one of the buttons to switch decks much like the <tab> key on your keyboard, with this you can switch from deck to deck.
(whincing, expecting to be called down since I'm not 100% sure of this)
geposted Wed 16 Apr 08 @ 9:33 am
Aaah - that makes sense. I would imagine this is the case...
If anyone else has an idea, please let me know.
geposted Wed 16 Apr 08 @ 10:03 am
Yes, you can program the 1 controler to run on both sides, it works just fine with just one.
geposted Wed 16 Apr 08 @ 12:21 pm
