I'v got it working but when I log nm to the given adress i can only hear 1 second of sound.
how can i fix this?
thax for all your help
how can i fix this?
geposted Thu 17 Apr 08 @ 12:07 pm
Do you have a firewall installed? are you using 3.4?
geposted Thu 17 Apr 08 @ 3:05 pm
I disabled the firewall, and yes i it's 3.4.
geposted Fri 18 Apr 08 @ 10:31 am
Which player do you use to listen? what bitrate do you use and what is your internet speed?
geposted Fri 18 Apr 08 @ 4:23 pm
No player just cut and paste the adress on Internet broaser, 94 mhz, and its at the moment sent from wireless,
I understand tha its beter to stream whit a internet cabel i will try that when i find the cabel.
What els should i think about?
thanx
thanx
geposted Sat 19 Apr 08 @ 10:54 am
