I have Numark cue version 5.07 and i have downloaded many skins and i have no idea how to get them to work? they don't come up in my skin options? what do i have to do to use them?
geposted Fri 18 Apr 08 @ 1:01 am
Once they are downloaded click on the red box they are self installing.....
geposted Fri 18 Apr 08 @ 8:19 am
Alrighty once you have downloaded the .exe double click it it will be installed to the skins folder it will say install suceeeded , and you will be able to choose it on config > skins.
geposted Fri 18 Apr 08 @ 9:53 am
i've done all that and out of 15 or more only one skin has shown up on my skins in the config menu.
geposted Fri 18 Apr 08 @ 2:55 pm
which skins?
geposted Fri 18 Apr 08 @ 4:18 pm
the only skin that I have gotten to work is the Sratch skin, all others won't come up in my menu.
geposted Tue 22 Apr 08 @ 3:55 pm
Ok then just put the zip files into Mydocuments/ Virtual Dj / Skins. BUT make sure the skins you are trying to use are 5.0 compatable as some are not.
geposted Tue 22 Apr 08 @ 7:17 pm
