Hi
I wonder if it's possible for you to consider a slight change to the logging feature on Virtual DJ / Numark Cue on the new version.
At the moment it logs tracks in the order they've been played (which is great) but if you choose to display the "Last Played" column then it doesn't give an accurate time, it only says 0hrs ago or 1hr ago etc etc
Usher Yeah 1hrs ago
Freemasons Uninvited 0hrs ago
Shapeshifters Lolas Theme 0hrs ago
It would be much better (in my opinion) if it said the date and time it was last played for example
Usher Yeah 24/3/2008 2038
Freemasons Uninvited 24/3/2008 2042
Shapeshifters Lolas Theme 24/3/2008 2048
I wouldn't have thought this would be a difficult feature to change, it does log the tracks this way in the .txt file
Usher Yeah 1hrs ago
geposted Fri 18 Apr 08 @ 11:36 am
It will give the date when it is over 12 hours , currently just not an exact time.
geposted Fri 18 Apr 08 @ 7:06 pm
Exact time is what i'm after really.
The venue I work in has two DJ's on a weekend and it's helpful to know specifically what time a track was last played
geposted Wed 30 Apr 08 @ 7:38 am
yeah, an accurate timing of when played would really be nice
....also I would like to see the time a song is allowed to play before it is logged should be a configuration setting. As it is now I think it is 20 seconds, so if you are trying out a mix or previewing a song it frequently shows up in the playlist even though you never really played it. I think we should be able to set how long a song is played before it is logged. As it is now it makes it hard to go over the other Dj's format (that as music director I am responsible to make sure they are keeping in line with the format) to tell exactly what they played in a given night.
geposted Fri 02 May 08 @ 4:50 am
That is setting can be changing in the registry - please see this documentation for How-to -- VirtualDJ 5 Features Guide (new features only) [ http://www.virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf ]
geposted Fri 02 May 08 @ 8:50 am
cool, thanks
geposted Fri 02 May 08 @ 8:28 pm
