Hiya, my friend is interested in beatmatching by ear and is curious how to disable the waveform? We've searched the forums and didn't find anything on it. Nor do we see anyway to remove it on the Atomix default skins.
geposted Fri 18 Apr 08 @ 9:02 pm
ive never seen this option to disable it... but this doesnt mean that its not available..
maybe you could try and wearing some really dark sunglasses and put some tape on the screen and try your best to not look at the waveform..
if this doesnt work ask again i have another suggestion...
geposted Fri 18 Apr 08 @ 9:28 pm
Disabeling this is not an option. Its a good feature to have. You mark your cues and beat match with this. If you want to mix with your headphones, just listen and dont look at the waveform.
geposted Fri 18 Apr 08 @ 9:38 pm
Lol
geposted Fri 18 Apr 08 @ 10:00 pm
It's simple, can be done with panels in skin. The skin OldSchool has that feature as an option.
geposted Sat 19 Apr 08 @ 1:48 am
It's great that VDJ supports skins, and many of these skins are of a top standard, but I think the official VDJ skin needs to be more customisable, with panels so the waveform can be divided, hidden etc, also so a real waveform can be shown.
geposted Sat 19 Apr 08 @ 4:31 am
