Salutations I own the hercules mk2 but on the master sound their is a high pitch noise all the time i do not know what this is. do i have to make some setting changes? please help
geposted Sat 19 Apr 08 @ 2:49 pm
Hi SFCMarioLuna,
DJ Console MK2 output level is +4dBu, so your high pitch noise may result from a saturation: the device in which you connect DJ Console MK2 may not support +4dBu level and may be designed for -10dBv level only, so you must attenuate DJ Console MK2 signal level.
1) If you connect DJ Console MK2 to an analogue mixer, turn the gain knob on this analogue mixer to 25% of the gain knob run,
2) If you connect DJ Console MK2 to a hifi system, you can attenuate DJ Console MK2 signal connecting an attentuator between the hifi input and the DJ Console MK2 output:
- an in-line volume control for headphones, as Shure PA235 or Koss VC20
http://www.shure.com/PersonalAudio/Products/Accessories/CasesAdapters/us_pa_pa235_level_attenuator
http://www.koss.com/koss/kossweb.nsf/p?openform&pc^ac^VC20
- an analogue audio console, as Behringer Xenyx 502 or UB 502
http://www.behringer.com/502/index.cfm?lang=eng
http://www.behringer.com/UB502/index.cfm?lang=eng
- a dedicated attenuator, as SM Pro Audio Nano Patch
http://www.smproaudio.com/index.php?option=com_content&task=view&id=24&Itemid=68
- a multimedia hub, as Trust Multimedia hub
http://www.trust.com/products/product_detail.aspx?item=12304
geposted Mon 21 Apr 08 @ 4:19 am
