Witch one is bigger in size?
Will the virtual vinyl soundcard fit in this seroto built sound card case? look at the photo in this link the seroto soundcard fits with no room to spare
http://www.idjnow.com/StoreModules/ProductDetails.aspx/PID=FZGSBM10W--BranchID=--DepartmentID=CASES%5ERACKS--SubDeptID=308--CategoryID=--DeID=0
geposted Sat 19 Apr 08 @ 8:06 pm
Also I'm going to be running total control midi with 2 turntables and virtual vinyl with cue
Does the virtual vinyl sound card have inputs for the MIC & HEADPHONE Cue like DJ/IO? or?
geposted Sat 19 Apr 08 @ 8:35 pm
It is a different in size so unless that case can be modded unfortunately not, the VV box is designed for use with a mixer so it does not have a mic or headphone jack.
Perhaps you could use a line mixer to manage your preview and mic and use the total control for the mixing.
geposted Sun 20 Apr 08 @ 9:18 am
can i use the djio & numark virtual vinyl sound cards at the same time? so i can still use the total control with I/O for mic and headphones?
geposted Sun 20 Apr 08 @ 3:59 pm
geposted Mon 21 Apr 08 @ 1:56 pm
No you would need to use a mixer cue would not allow this currently.
geposted Mon 21 Apr 08 @ 3:36 pm
hey i have the exact same coffin and my vv box does fit in that slot.
geposted Mon 21 Apr 08 @ 11:48 pm
Great it looks a great case , thanks for the info.
geposted Tue 22 Apr 08 @ 7:58 am
